Electronic circuits & projects forum - Need help with electronic circuits & projects?  Forum Index Electronic circuits & projects forum - Need help with electronic circuits & projects?
Electronics circuits, projects, schematics discussion forum for Electronic hobbyists, engineers and students to share and discuss problems, ideas, views and general information related to Electronics on the Internet!
 FAQFAQ   SearchSearch   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
[Electronic circuits and hobby Home page]
Need help finding the right I/O controller.
Post new topic   Reply to topic    Electronic circuits & projects forum - Need help with electronic circuits & projects? Forum Index -> Electronic Parts forum
View previous topic :: View next topic
Author Message
einklienermench
PostPosted: Sun Jun 06, 2010 7:15 pm    Post subject: Need help finding the right I/O controller. Reply with quote
Hi everyone im new to this forum and i need your help guys, as far as i see there are allot of professionals out here and i hope we will be able to find a solution to my problem.
Here is the map of the system and how it is interconnected;
i need to be able to get the signal from lead 8 to go to lead 6 and make lead 5 go to lead 4.
I need to be able to switch between the transmitters that i want to amplify on the go without any restarts and keep ongoing connections through the controller (non amplified signals that go straight through example:
Lead 9 goes to lead 3).
Example command sequence:
AMPLIFIER_on
Bluetooth -> amp -> antenna1.
after a minute
Bluetooth -> antenna2
Zigbee_on
Zigbee -> amp -> antenna1.
and such and such. Doing all that without interrupting that acme wi-fi that is connected at all times to antenna3.
Hope you understand.
I need to be able to switch the signal "route" from the transmitter to the antenna. i need to be able to choose if i want to amplify the signal of the transmitter via software.
I Need for that signal that is already by todays standards respectively loud. (20dbm is considered strong), to go through the amplifier and output it to a special antenna.
so you see that its basically an I/O Controller, but the difference is that i need one that can handle such wattage.
And for those who wonder while looking at the illustration why i got 6 transmitters and 4 antennas its simply that all the transmitters work at 2.4GHz band and for all of them to work at the same time i will simply run out of band to work with, thats why there will be only 3 devices active at a time so i can use all three "ACME" Devices while intel wi-fi is inactive. so i can use all three non-overlapping channels of the 2.4ghz band. (in Europe there are 13 channels i believe).
I need the controller to connect via USB interface (up to usb 3.0), power will come from external source - it would be awesome if it wouldnt but i keep my options open. (battery/acdc converter)
So please read the whole post, its complicated yet i believe possible.
Thanks to anyone who cares to help.
Back to top
View user's profile Send private message
Display posts from previous:
Post new topic   Reply to topic    Electronic circuits & projects forum - Need help with electronic circuits & projects? Forum Index -> Electronic Parts forum All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
