| View previous topic :: View next topic |
| Author |
Message |
mcontroller05
Posted: Wed Jan 20, 2010 5:47 pm Post subject: microcontroller with GSM |
hi i want to learn microcontroller and want to use a GSM modem with it. can anyone advise where i can find some tutorials or code. more over where can i buy some source code for this.
thx _________________ www.irfulabs.com |
| Back to top |
martine4161
Posted: Fri May 21, 2010 11:47 am Post subject: |
| If you want to learn about the micro controller then try out the basic theory of it by website and before that you can refer the book for that. But you have to search for the GSM technology so you can get the theory what you want. |
| Back to top |
kendustin7
Posted: Fri May 28, 2010 9:04 am Post subject: |
I have read one article about this in one of the electronics magazines. I think you can start learning with microcontroller serial communication and it will be good to use tx,rx simple interface with gsm module . _________________ movie trailers |
| Back to top |
nwilliams
Posted: Sat May 29, 2010 6:36 am Post subject: |
Micro controller is a single integrated circuit. It has processor core, memory and programming section in it. GSM modem accepts a SIM card and operates just like a mobile phone. It is used for data information. There must be a command through which can support GSM modems. _________________ bad credit credit card |
| Back to top |
alexrock23
Posted: Wed Jun 02, 2010 7:04 am Post subject: |
You should learn AT commands for GSM communication. First connect your GSM modem with your PCs serial port then send AT commands to it using Terminal/Hyperterminal, in this way you can learn the commands and check the status of modem. _________________ discount voucher code |
| Back to top |
smithdsouza
Posted: Tue Jun 08, 2010 5:48 am Post subject: |
| Micro controller as the name itself suggest is a small computer integrated on a single IC.It contains processor core, programmable i/o unit and memory.It is used in automatically controlled programs and devices.GSM modem is used to insert sim card through which you can access data of the card. |
| Back to top |
