Electronic circuits & projects forum - Need help with electronic circuits & projects?  Forum Index Electronic circuits & projects forum - Need help with electronic circuits & projects?
Electronics circuits, projects, schematics discussion forum for Electronic hobbyists, engineers and students to share and discuss problems, ideas, views and general information related to Electronics on the Internet!
 FAQFAQ   SearchSearch   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
[Electronic circuits and hobby Home page]
Vibration... ?
Post new topic   Reply to topic    Electronic circuits & projects forum - Need help with electronic circuits & projects? Forum Index -> EE quiz questions & problems
View previous topic :: View next topic
Author Message
Manny-
PostPosted: Fri Sep 04, 2009 10:06 am    Post subject: Vibration... ? Reply with quote
Hello, im new here,
i have been trying to find out about this everywhere but had no luck my question is this:
How does a motor spin/vibrate with audio? e.g. like the PS2 controller, it vibrates with the sound. how do i make this? what components will i need?
any help at all will be appreciated Smile
thanks in advance
Back to top
View user's profile Send private message
Manny-
PostPosted: Sat Sep 05, 2009 1:37 pm    Post subject: Reply with quote
Bump- please someone help...
Back to top
MikeT
PostPosted: Sat Sep 05, 2009 2:12 pm    Post subject: Reply with quote
A small motor with an offset balance or are you asking how sound is converted into voltage?
_________________
Mike
Back to top
Manny-
PostPosted: Sun Sep 06, 2009 2:31 pm    Post subject: Reply with quote
Yes im asking how sound is converted into voltage, i want the vibrating motor to vibrate with sound creating vibration as the sound gets higher and lower just like phones when it rings the little motor vibrates with the sound (i hope this makes sense)
Back to top
Manny-
PostPosted: Mon Sep 07, 2009 12:46 pm    Post subject: Reply with quote
Bump once again... come on please someone reply, this is afterall a electronics circuits website someone should know how this is done please help
Back to top
PostPosted: Mon Sep 07, 2009 2:54 pm    Post subject: Reply with quote
Like Mike said, you can use an offset weight on the end of the motor shaft to make it vibrate.
But the motor is a rotary device that has inertia when it is running so there is no way you can make it change its speed of vibration to match the audio frequencies of speech or music.
Back to top
Manny-
PostPosted: Tue Sep 08, 2009 12:07 pm    Post subject: Reply with quote
thanks for the reply, i appreciate it.
I was thinking there may be a way because the PS2 controller does the same thing when you hear a loud sound like a gun shot the controller vibrates with it... i just thought there may be a way to do that
but now i know there isn't, thanks again Smile
Back to top
rosetaylor01
PostPosted: Wed Sep 30, 2009 11:57 am    Post subject: Reply with quote
use offset weight on the end of the motor shaft to make it vibrate but i think it is not possible to generate sound through this because motor cant produce the high vibration in the sense of converting vibrating power to sound.
_________________
rose taylor
Back to top
View user's profile Send private message Send e-mail
MikeT
PostPosted: Fri Oct 16, 2009 8:06 pm    Post subject: Reply with quote
I know what you mean about the game controllers. They're like the sound-to-light systems only you want sound to vibration. Sure it's possible but I don't know how (yet). However...
Doesn't a microphone convert sound to an electrical signal? And don't transistors amplify signals into useable voltage?
_________________
Mike
Back to top
smithshn
PostPosted: Tue Jun 29, 2010 1:21 pm    Post subject: Reply with quote
In this case you should pass voltage of the voice or music in the motor which is a rotary device that has inertia when it is running.
_________________
8gb pro duo
Back to top
PostPosted: Tue Jun 29, 2010 2:34 pm    Post subject: Reply with quote
I don't understand what you mean. Can you explain more?
Back to top
Display posts from previous:
Post new topic   Reply to topic    Electronic circuits & projects forum - Need help with electronic circuits & projects? Forum Index -> EE quiz questions & problems All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
