Q point for a BJT
Q point for a BJT
Postby didi10 » Tue Dec 04, 2012 4:16 pm
I need a relationship (equation) between Cpi and the Q point for a BJT.
didi10
Re: Q point for a BJT
Postby sachinelectrostar » Fri Oct 11, 2013 9:16 am
Vbe - Vcc + (Ic + Ib)Rc + IbRb = 0
sinc Ic >> Ib we can simplify to
Vbe - Vcc + IcRc + IbRb = 0
because Ib = Ic/beta we can solve for Ic to get
Ic = (Vcc - Vbe) / (Rc + Rb/beta)
sachinelectrostar
Postby dscpcb » Fri Sep 11, 2015 12:38 pm
The Q, or quiescent point, is the DC level, or where the circuit produces no noise.
The first thing to do would be to Thevenize the left side of the circuit; Vth = 24K/(24K+96K) * Vcc, Rth = 96K in parallel with 24K.
Once you solve those, you will have a circuit with an a voltage source on the left (Vth) and a resistor, Rth, between Vth and Vbe.
To solve for the current i(b), use i(b) = (Vth - Vbe)/Rth
Once you have i(b), you should be able to find i(c) and Vce, and then verify that the circuit is in active mode.
dscpcb
Postby bwetman » Mon Dec 28, 2015 12:42 pm
Hello,
The operating point of a BJT, also known as bias point or quiescent point (or simply Q-point), is the DC voltage and/or current which, when applied to a device, causes it to operate in a certain desired fashion.
bwetman
CTI 2572 ETHERNET MODULE MEMORY CHIP VERSION 6.7
$45.0
CTI 2572 ETHERNET MODULE MEMORY CHIP VERSION 6.7 pictureMini Memory Shield Module Mciro TF Card SPI Micro Storage Expansion Board
$1.19
Mini Memory Shield Module Mciro TF Card SPI Micro Storage Expansion Board pictureCasio FX-350ES PLUS Scientific Calculator 252 FUNCTIONS 9 Memories VPAM FX-
$0.99
Casio FX-350ES PLUS Scientific Calculator 252 FUNCTIONS 9 Memories VPAM FX- pictureMicron MT5C6408-15 memory chip 64K 28pin DIP SOJ Never Used -full sleeve of 25
$25.0
Micron MT5C6408-15 memory chip 64K 28pin DIP SOJ Never Used -full sleeve of 25 picture
