US AC Adapter to AU AC Adapter
Postby lynzoid » Sun Nov 29, 2015 2:22 am
Input: AC 120V 60Hz 54mA
Output: AC 12v 250mA Max 3W
My dad says if I get a US to AU plug converter it will just blow the device up and says I need
to buy an identical cord for output that's AU. If so what would I get ?
lynzoid
Re: US AC Adapter to AU AC Adapter
Postby Relayer » Sun Nov 29, 2015 10:18 pm
Hello lynzoid,
I'm assuming you're living in a 240V AC country. if so, then your dad is correct. It will blow the device up.
You're going to need a step-down transformer, something similar to the link below:
Step-Down Transformer
It might be best to shop around for better prices, though 45 bucks Aussie dollars isn't too bad.
I hope the above helps. :)
Relayer
Relayer
Postby pebe » Mon Nov 30, 2015 4:23 pm
The specified input of '125VAC' shows that it uses a mains transformer and as Relayer said it will blow up on a 240V supply.
A better bet would be a switch mode power supply (SMPS). These normally have an input voltage range that spans both of those voltages. Commonly known as 'wall warts' they are cheap and efficient, and there are hundreds on ebay.
Furnas Heavy Duty Limit Switch 60LAL2A Adjustable Radius Lever 1.5-3.5R A *NEW*
$35.0
Furnas Heavy Duty Limit Switch 60LAL2A Adjustable Radius Lever 1.5-3.5R A *NEW* pictureHID 920NTNNEK00000 iClass SE R40 Wall Switch Reader - Black WITH BACKPLATE
$41.0
HID 920NTNNEK00000 iClass SE R40 Wall Switch Reader - Black WITH BACKPLATE pictureFour Channel 4 Route MOSFET Button IRF540 V2.0 MOSFET Switch Module Arduino
$0.99
Four Channel 4 Route MOSFET Button IRF540 V2.0 MOSFET Switch Module Arduino pictureGENIE 105115, 105115GT, JOYSTICK STEER SWITCH REPAIR KIT
$20.0
GENIE 105115, 105115GT, JOYSTICK STEER SWITCH REPAIR KIT picture
