V simple help needed
Postby Hughsie » Sun Jan 29, 2012 6:59 am
Hi, I've signed up to this forum as I need some very simple advice please. If I give you the problem that might me the best place to start. Basically, I need a container filling with water to a certain level and then to empty and this process repeated every hour. I know that I could achieve this with a bell syphon but would rather a break in the water flow ie the filling and emptying needs to be done over a relatively short time scale. So, I have a pump that fills the container with water, I obviously need some kind of switch that will stop it at a certain level. But I need some timing device that says to the pump - an hr after the water got to the top ( and then drained) kick in and repeat process. My thoughts were if I had a pump that pumped water twice as fast as the outflow then I would not have to worry about a release mechanism for the water to leave. However, I think there must be some kind of plumbing device out there that releases water out at once ?
Hope this makes sense !!
Hughsie
PHILIPS ADVANCE IMH-39-G-BLS ELECTRONIC HID BALLAST 39W E-VISION BOTTOM LEADS
$75.0
PHILIPS ADVANCE IMH-39-G-BLS ELECTRONIC HID BALLAST 39W E-VISION BOTTOM LEADS pictureNew HATCH Ballast (2) Lamp - 13 Watt 277 VAC 50/60 Hz Model SWB-13-2-277
$11.99
New HATCH Ballast (2) Lamp - 13 Watt 277 VAC 50/60 Hz Model SWB-13-2-277  pictureGrainger LumaPro 1XUG5 Ballast Ignitor, 1000W HPS (No Box)
$61.3
Grainger LumaPro 1XUG5 Ballast Ignitor, 1000W HPS (No Box) pictureHalco M57/175CWA/4T/K ProLume Metal Halide Ballast Kit (New)
$34.25
Halco M57/175CWA/4T/K ProLume Metal Halide Ballast Kit (New) picture
