replacement for toroid core
Postby luffy » Sun Jun 14, 2015 7:36 am
hi is there any way i can replace toroid core from the circuit?.
there is this circuit which requires a toroid core to function. a toroid core AL=25 with 6 turns of wire. for i know i can get the inductance value required to it from this formula, n=1000[sqrt(L/AL)] . and make an air coil inductor out of that inductance value. but i am not sure if it would really work as toroid cores do since the author of the circuit says the circuit wont work without toroid core.
toroids here in our local electronic stores are not available thats why i cant provide it in my circuit.. any help with this would be much appreciated. thanks.
luffy
Re: replacement for toroid core
Postby PradeepKumar » Mon May 29, 2017 12:17 pm
Amidon's FT-114-67 has a AL of 25 and is good up to about 50MHz. It's a bit on the large side for 6 turns, but that's nothing a hot glue gun can't fix (no pun intended).
PradeepKumar
SIEMENS 6ES7 312-5AC02-0AB0 SIMATIC S7 PLC CPU MODULE, 6 MONTHS WARRANTY
$299.0
SIEMENS 6ES7 312-5AC02-0AB0 SIMATIC S7 PLC CPU MODULE, 6 MONTHS WARRANTY pictureHobart 00-436422 Ejector, White for Food Processor Model FP150
$84.99
Hobart 00-436422 Ejector, White for Food Processor Model FP150 pictureMitsubishi New FX5UC-32MT/D CPU Unit (DC) 24 V (I/O control system)
$411.43
Mitsubishi New FX5UC-32MT/D CPU Unit (DC) 24 V (I/O control system) pictureMitsubishi New Q Series CPU Unit Q13UDHCPU (I/O control system)
$1924.43
Mitsubishi New Q Series CPU Unit Q13UDHCPU  (I/O control system) picture
