Which part is this, see picture
Postby ben39 » Tue Feb 24, 2015 10:46 am
Which part is this?
It comes from silva/nexus wind transducer unit.
In front of these sensor is a ball with black and white colors.
By good operation my measurement is:
pin 1: 10,5V
Pin 3: switch from 10,5V to 6V when the ball turns.
I 'am looking for a part number, that I can use as replacement.
replacement need to have same dimensions.
Dimension: front 4,6mm x 5,7mm side 2,3mm
Someone can help me with these?
Ben
sensor 1 [1600x1200].JPG (85.53 KiB) Viewed 14526 times
sensor 2 [1600x1200].JPG (65.73 KiB) Viewed 14526 times
ben39
Re: Which part is this, see picture
Postby ben39 » Tue Feb 24, 2015 10:19 pm
Thanks Ken
looks like the same
ben39
NEW SCHNEIDER LC1D50G7 CONTACTOR 40HP @ 460V 120V COIL
$200.0
NEW SCHNEIDER LC1D50G7 CONTACTOR 40HP @ 460V 120V COIL picture2M Soft Round Copper Tube Pipe Coil Refrigeration OD 4mm x ID 3mm
$7.35
2M Soft Round Copper Tube Pipe Coil Refrigeration OD 4mm x ID 3mm picture10" Drill Press Quill Feed Return Coil Spring Assembly 5.4cm x 1cm W8N2
$2.8
1010" Drill Press Quill Feed Return Coil Spring Assembly 2" O2H1
$3.11
10
