Emulating a throttle
Postby A_edwill » Mon Feb 22, 2016 5:14 am
Looking for a circuit for linear voltage isolation. I am running 0 - 4.7vdc output from an Arduino board via a DAC. Output must be linearly transferred to a motor controller which has its own 5vdc supply and ground. http://www.monsterscooterparts.com/24v- ... oller.html. Basically I am trying to imitate a throttle. Tried an H11F1 circuit, was able to create an isolated linear voltage circuit but it fails when hooking up to the 3 wire throttle sensor wires on the controller. :?
A_edwill
Re: Emulating a throttle
Postby pebe » Tue Feb 23, 2016 5:59 pm
I don't know what you mean by 'linear voltage isolation'. The output from your DAC is an analogue voltage. You can only isolate (from DC) an AC waveform, so what exactly is the type of voltage you wish to transfer? Or are you intending to use a pulse of variable amplitude and want a circuit for it?
3- LG CRN-8245B CD-Rom Drive IBM 06P5262 REMOVED FROM UNUSED SERVER X305 E 305
$4.95
3-  LG CRN-8245B  CD-Rom Drive IBM 06P5262 REMOVED FROM UNUSED SERVER X305 E 305 pictureCA1530H01 Melco 80MM MMF-08G24DS RC4 80*80*25 mm DC 24V 0.10A server Cooling Fan
$16.88
CA1530H01 Melco 80MM MMF-08G24DS RC4 80*80*25 mm DC 24V 0.10A server Cooling Fan pictureBrand new Magic MGA5012XS-A10 DC12V 0.19A Blower fan Server Cooling Fan 5.5cm 2P
$9.99
Brand new Magic MGA5012XS-A10 DC12V 0.19A Blower fan Server Cooling Fan 5.5cm 2P pictureIKURA 6250MG1 220V 50/60HZ 3-pin AC 160x160x55mm Server Square Cooling fan
$99.88
IKURA 6250MG1 220V 50/60HZ 3-pin AC 160x160x55mm Server Square Cooling fan picture
