Electric tiny moving mecanism
Postby acidmanvl » Thu Sep 10, 2015 12:41 pm
Hi, I'm looking for a way to moves four small objects in up position and lock thems up(all four objects need to be really close together,
around 1/2 cm2 on surface for all four, depth of the whole macanism could be around 2 cm and the device can be long, not large).
It could be small pins or wires or balls of some sorts going up of around 1 or 2 mm.
I was thinking of some sort of "bistable solenoid" but it needs to be really small.
Maybe moving a pin under a other object to make it go up while being locked by the pin. But it needs to be bistable(no electricity required to stay in both, up and down position).
I'm totally newb. to electronic parts and what actually commonly exist so any king of help and ideas on the tech I could use would be really appreciated.
acidmanvl
Re: Electric tiny moving mecanism
Postby KMoffett » Thu Sep 10, 2015 8:50 pm
I'm not sure I understand your explanation. Can you post a sketch of what you're envisioning?
Postby acidmanvl » Thu Sep 10, 2015 9:39 pm
Ok I'll go to straight to the point, I want to make a cheaper braille cell,
here is how braille cells actually work:
http://www.cim.mcgill.ca/~jay/index_fil ... ll-big.jpg
acidmanvl
Postby KMoffett » Fri Sep 11, 2015 1:55 am
How fast do they need to move during changes?
Postby PradeepKumar » Fri Sep 30, 2016 11:40 am
The technology of the bistable solenoid is more advanced than that used in simple linear devices.
PradeepKumar
METABO HEAVY DUTY 6" ANGLE GRINDER MODEL WEP 14-150 PADDLE SWITCH TYPE 120V
$9.95
METABO HEAVY DUTY 6Speed Control Switch 12V-40V 10A Pulse Width Modulation PWM DC Motor 13KHz Y7X7
$7.71
Speed Control Switch 12V-40V 10A Pulse Width Modulation PWM DC Motor 13KHz Y7X7 pictureLED Light Bar Relay Switch Control Wiring Harness Kit Fuse Relay 12V 40A Work US
$11.99
LED Light Bar Relay Switch Control Wiring Harness Kit Fuse Relay 12V 40A Work US pictureRca 5 switch Tip 425
$9.4
Rca 5 switch Tip 425 picture
