Stupid Series/Parallel Question
Postby bakgerman » Tue Aug 19, 2014 8:26 pm
Please see this link below.
http://puu.sh/aZrzG/472f1f6d00.png
My question is simple. WHY??
bakgerman
Re: Stupid Series/Parallel Question
Postby I_Daniel » Wed Aug 20, 2014 1:16 pm
Placing the two in series I would say that the resistance is increased and a 48 volt supply will become necessary.
Postby yadavvlsi » Fri Aug 22, 2014 3:29 pm
When ever you are connecting multiple devices to same supply you should connect in parallel only. Parallel voltage remains same. Series voltage is divided. In first case there will voltage drop across the seleniod i.e. voltage across motor terminal will be lesser than 24Volt. Also, current will be limited to 0.3A due seleniod while current requirement for motor is 0.7A.
http://en.wikipedia.org/wiki/Voltage_divider
yadavvlsi
Postby I_Daniel » Wed Aug 27, 2014 6:44 am
Right. What have these two replies told you?
The first thing to learn is the most basic of all when starting in electronics. It is Ohms Law. Without first learning Ohms Law you may as well give up.
Users browsing this forum: No registered users and 12 guests
