Hello all,
Am new to electronics and playing around is all. I bout an NPN transistor from radioshack, but when I look up any online resistor calculators none of the fields they ask for, are on the data sheet for the transistor.
Am assuming that perhaps they're using different terminolgy, thought I'd reach out for some help.
Also, really just want to use this for a switch to light up an LED or two. Not even sure if it's too much or too little for a 6V battery supply.
Many thanks,
Sergio
TIP120 Darlington Transistor
Power Dissipation 65W
Collector-emitter voltage 60V
Collector-base coltage 60V
Emitter base V 5V
Collector current (cont) 5.0A
Collecor curretn peak 8.0A
Base current 120mA
Unclamped inductove load energy 50mj
