| View previous topic :: View next topic |
| Author |
Message |
nander
Posted: Sat Oct 31, 2009 1:49 pm Post subject: NAND to NOR |
Hello everyone !
So i have to turn this circuit that is made of nand gates into the equivalent of this but this time only with NOR gates. This is the circuit :
First i tryed to turn the circuit into some boolen algebra statement but nothing happned, actually it became harder =/ i am strungling trying to solve this loads hours ....help me please... |
| Back to top |
lem787
Joined: 19 Sep 2006 Posts: 232 Location: Bath, England
Posted: Sat Oct 31, 2009 8:06 pm Post subject: |
| Is there a limit to the amount you can use? |
| Back to top |
sandratycova
Posted: Thu Nov 05, 2009 10:24 am Post subject: |
Hello Nander,
I am so impressed about your post regarding digital gates you are using and regarding you problem i have convenient solution about it.That you must prefer to OR gates and Inverters that is NOT gates.There are cheap to in market comparing with NOR gates.Actually recently I don't have any pictorial information regarding this topic.When I will get it will be forwarded to you. _________________ disque dur externe |
| Back to top |
rizwanhirani
Posted: Tue Nov 10, 2009 5:33 am Post subject: |
I think it is very easy to crack it..
You just have to employ basic fundamentals of the digital electronics..
I have solved it at my end on paper..I don't have scanner ..
I give you trick ..
Nand = " And " then "Not"
And = bubbled "OR"
now shift the bubbles and reduce the circuit ..that's all..
Apart from that remember one thing about nand and nor ..if both input are shorted either in nand or nor it is same as inverter..so wherever ther is a shorting of the two inputs of the nand it is as good as sorting of the two input to the nor
I hope you will be able to do it now.. any ways I don't attached the step but attached the final schematic for your information
let me know if you are unable to do it _________________ Best Regards,
Rizwan Hirani |
| Back to top |
