Electronic circuits & projects forum - Need help with electronic circuits & projects? Electronics circuits, projects, schematics discussion forum for Electronic hobbyists, engineers and students to share and discuss problems, ideas, views and general information related to Electronics on the Internet!
| View previous topic :: View next topic |
| Author |
Message |
fi
Posted: Fri Oct 30, 2009 10:41 pm Post subject: Heating Element |
Hi everyone,
Im a design student and are currently really stuck on a project that im working on.
My problem is I have a container filled with 700ml of tap water at 10 deg C i need to pass it through a heater. When it comes out of the heater it needs to be 37 deg C.
One idea I was looking at the tefal quick cup kettle inside it has a hollow element which draws water up through it and heats it up. I thorght this was a good way to do heat my water but i cant buy this element anywhere or find anything similar. Therefore i was wondering if i could build my own one using a pipe and wrapping nichrome wire around it and then running the water through it to heat it up. My problem is that I dont have much time to test and experiment and was wondering if i can work out the length of pipe i would need and the voltage and current i would need to heat the pipe so that it raises the temp of the water to 37 deg c. The water is at a flow rate of 2.6ml/s and the product must be connected to the mains.
Is this possible does anyone think it will work and if so what equations would i need to work it out? Ideally the heater section needs to be as small as possible. Any help or ideas would be greatly appreciated many thanks!! |
| Back to top |
Joined: 09 Dec 2003 Posts: 1090 Location: Ellon, Scotland
Posted: Sat Oct 31, 2009 9:46 am Post subject: |
You should be able to work out the power requirements from this:
It takes 1calorie to raise 1gm(mL) of water by 1deg C.
1calorie ≈ 4.2joules.
1joule = energy given by 1watt in 1sec. |
| Back to top |
laracroft
Posted: Mon Nov 09, 2009 7:28 am Post subject: |
Hi fi,
This is Lara Croft, I read your entire post.
I am agree with pebe. You should try pebe's idea.
Have a nice day! _________________ psp zubehör |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
