Electronic circuits & projects forum - Need help with electronic circuits & projects?  Forum Index Electronic circuits & projects forum - Need help with electronic circuits & projects?
Electronics circuits, projects, schematics discussion forum for Electronic hobbyists, engineers and students to share and discuss problems, ideas, views and general information related to Electronics on the Internet!
 FAQFAQ   SearchSearch   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
[Electronic circuits and hobby Home page]
Help!!!
Post new topic   Reply to topic    Electronic circuits & projects forum - Need help with electronic circuits & projects? Forum Index -> Electronic Circuits Help
View previous topic :: View next topic
Author Message
miller888
PostPosted: Thu Oct 15, 2009 9:15 am    Post subject: Help!!! Reply with quote
Hi everyone. I am new on here and need a bit of advice if possible. I have been given a project from school and my knowledge is on circuits is limited (however, willing to learn)! I must design a circuit that:
Allows the user to activate the circuit when required
The circuit must run for 2 seconds and then stop. It must then be able to run for another 2 seconds and stop.
Once the circuit has ran for 4 seconds the circuit must not be able run again for at least 10 minutes.
Sorry if this does not make a lot of sense as i say its not my best subject but require an A for next year! Any helped would seriously be greatly recieved.
Lee
Back to top
View user's profile Send private message Send e-mail
miller888
PostPosted: Thu Oct 15, 2009 9:18 am    Post subject: Reply with quote
sorry probably helpful if I tell you it is a circuit for a battery operated air freshener! Cheers
Back to top
kanishuw
PostPosted: Sat Oct 17, 2009 1:41 pm    Post subject: Reply with quote
This can be done in one of many ways. I will suggest the following method for very accurate operation.
You can use a microcontroller (PIC) for this. A PIC (Programmable IC) is a very common IC which we can program according to our needs. I recommend you to buy a 16F84 PIC. It has 18 pins. You will have to buy a programmer circuit as well. Using MikroC language you can program the PIC. In the code you will simply code the logic which you want the device to perform.
I guess this is the best and the easiest way you could get accurate results. There are other methods in which you will be using RC oscillators and counter ICs but you'll have to go through some tedious calculations to get good results.
cheerzzzz...
P.S.
In case you need further help send me an email on kanishuw@gmail.com
I can provide you the MikroC code and may be the circuit diagram as well
Back to top
laracroft
PostPosted: Sat Nov 07, 2009 10:04 am    Post subject: Reply with quote
Hi Kanishuw,
Myself Lara, Hey Miller you should try tip shown by kanishuw. I also finished similar project.
This is best and easiest way to get accurate results.
Now cheers.
_________________
psp zubehör
Back to top
sandyrochard
PostPosted: Sat Nov 07, 2009 1:00 pm    Post subject: Reply with quote
Hi Miller,
I am Sandy Rochard i gone through post well i can provide you links from where you can get your complete details as you require.
ambient.media.mit.edu/~circuits/ .
Back to top
Display posts from previous:
Post new topic   Reply to topic    Electronic circuits & projects forum - Need help with electronic circuits & projects? Forum Index -> Electronic Circuits Help All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
