Electronic circuits & projects forum - Need help with electronic circuits & projects?  Forum Index Electronic circuits & projects forum - Need help with electronic circuits & projects?
Electronics circuits, projects, schematics discussion forum for Electronic hobbyists, engineers and students to share and discuss problems, ideas, views and general information related to Electronics on the Internet!
 FAQFAQ   SearchSearch   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
[Electronic circuits and hobby Home page]
Need simple batterie powered bright LEDs for wedding
Post new topic   Reply to topic    Electronic circuits & projects forum - Need help with electronic circuits & projects? Forum Index -> Electronics newbies
View previous topic :: View next topic
Author Message
Swanky
PostPosted: Mon Mar 16, 2009 6:10 pm    Post subject: Need simple batterie powered bright LEDs for wedding Reply with quote
I tried to do this very simply using the batteries and LEDs in the online design for LED Throwies, but these LEDs are so dim, a firefly would outshine them by a mile!
We are hanging paper lanterns in the trees at our wedding and I want to use LEDs in them so we don't have to try to run wires all over the yard. I figure we can put them up and they should run all night without a problem.
I know zero about this sort of thing. My plan is to look through sites that sell LEDs for the one with the brightest bulbs and the widest angle, and then I need to figure out what batteries to use and use the formula to figure out a capacitor to go in between. I am just not sure about any of that exactly.
I'd appreciate any simple ideas. I will solder what is needed and get to the electronics store for parts like battery holders and anything else needed. I just have to get this figured out in the next month or so.
Thanks!
Back to top
View user's profile Send private message Visit poster's website
lem787
PostPosted: Mon Mar 16, 2009 6:48 pm    Post subject: Reply with quote
Isn't this the best man's job?
One thing to ensure is that the battery voltage is greater than the voltage drop of the LED. This drop depends largely on colour and efficiency. Red, for example, typically drops about 1.7V so 2xAA batteries giving 3V would suffice. However blue and (more relevently) bright whites can drop around 3.4V, and in the absence of a convenient 3.4V battery you would have to go up to 3xAA. Obviously there are other batteries besides AA but I can't think of anything more cost-effective.
You mentioned a capacitor; 'tis actually a resistor you require.
Vs-Vf/If = R (Battery voltage - Voltage drop / Current = Resistor value)
Back to top
Swanky
PostPosted: Mon Mar 16, 2009 6:50 pm    Post subject: Reply with quote
Yes, resisitor is what I meant.
I think I can get a AA batterie holder easy enough that holds 3 batteries. I want to use a white LED.
Back to top
lem787
PostPosted: Mon Mar 16, 2009 7:10 pm    Post subject: Reply with quote
I would advise you to try a couple of resistor values. It's easy to assume with an LED that brightest (maximum forward current) is best, but modern 50,000mcd LEDs can put out surprisingly huge amounts of light and may rather spoil the lantern effect, turning it into more of a "photon cannon". Perhaps try 15mA and 30mA.
4.5-Vf/0.015=R dim
4.5-Vf/0.030=R bright
Assuming the drop is no greater than 3.5V, the resistor should be between 30 and 100 ohms. A 220R pot in series with a 22R resistor would let you fine-tune.
Back to top
Swanky
PostPosted: Mon Mar 16, 2009 7:16 pm    Post subject: Reply with quote
Okay, speak s-l-o-w-l-y. Wink I'm afraid the terms you are using I don't know.
Yes, I don't want to light up the woods, just give a nice glow to the paper lanterns. Something close to a 4 watt night light. in brightness. And knowing that LEDs are pretty directional. I may have to rig some sort of diffuser on it with tissue paper or something.
So, please break it down to me in terms of what sort of materials to get for the job.
Back to top
lem787
PostPosted: Mon Mar 16, 2009 7:57 pm    Post subject: Reply with quote
The problem is this: LEDs vary so wildly that I cannot give you any "fixed" terms (minus the technicalities) without knowing what LEDs you are planning to use. I could suggest some, but I don't know if you have access to the same ones.
As a starting point; where are you from and do you have an ebay account?
Back to top
Swanky
PostPosted: Mon Mar 16, 2009 8:03 pm    Post subject: Reply with quote
I'm in East Tennessee, USA. Ebay yes.
I can get materials at the local electronics store, and really, they may be super friendly and help me with this.
I bought LEDs using this site as a guide and got the wrong ones. I got the 105PWD which was way, way too dim. Is the lv value the brightness? Maybe if I got the non-diffused ones, they would do the job. They are about 8 times brighter.
Back to top
Swanky
PostPosted: Mon Mar 16, 2009 8:30 pm    Post subject: Reply with quote
Okay, so, if I get these LEDs which have a 70 degree angle and 8-13k lumens, do you think that would do the job? And what would I need to power this?
Back to top
lem787
PostPosted: Mon Mar 16, 2009 10:57 pm    Post subject: Reply with quote
The top two on that site will be fairly bright but are quite inefficient.
The "Iv@100mA" refers to brightness at a specific current. 100mA is alot of current for that brightness and will drain 3xAA batteries in a few hours.
The brightness itself is measured in millicandela, or mcd.
The reason I asked about ebay is because of these...
http://cgi.ebay.com/100pcs-5mm-20000mcd-LED-Lamp-Ultra-Bright-White-DIY_W0QQitemZ350172834733QQcmdZViewItemQQptZCycling_Parts_Accessories?hash=item350172834733&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Four times brighter and more efficient.
Back to top
Swanky
PostPosted: Tue Mar 17, 2009 1:23 pm    Post subject: Reply with quote
What about these? This was suggested to me for the project. It has a 360 degree light, is bright and runs off 2 AA batteries.
Back to top
Swanky
PostPosted: Tue Mar 17, 2009 2:35 pm    Post subject: Reply with quote
Sorry. Here is the right link with specs.
Back to top
lem787
PostPosted: Fri Mar 20, 2009 6:20 pm    Post subject: Reply with quote
According to the datasheet those LEDs are <500mcd, which is pretty dim. Also 360'deg is quite deceptive, since you do not get the same intensity from all angles; at some angles there is barely any intensity at all.
Since this is for your wedding, it's all to do with the look and feel of the light and I don't think that can be interpreted with datasheets (certainly not by me). You don't want it to look naff and I think the only way you can achieve what you want is to get a small selection of different types and see what best suits your needs. If you need some help with resistor values at that point then I will be happy to lend some assistance but I can't accept the weight of responsibility for choosing the right lights for your wedding!
My apologies (and good luck) Smile
Back to top
liveinlove2112
PostPosted: Sun Nov 01, 2009 8:28 pm    Post subject: Re: Need simple batterie powered bright LEDs for wedding Reply with quote
Thanks!
Great idea... let me know how it went and what type of bulb you ended up using!!
_________________
-Kristina
Helping plan your Wedding Vegas and your San Francisco Wedding
Back to top
Display posts from previous:
Post new topic   Reply to topic    Electronic circuits & projects forum - Need help with electronic circuits & projects? Forum Index -> Electronics newbies All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
